Railroad Line Forums - Painting Zamak
[ Active Members: 3 | Anonymous Members: 0 | Guests: 319 ]  [ Total: 322 ]  [ Newest Member: SandersReview ]
 Painting Zamak
Author Previous Topic: Parts Diagram for an Athearn SD-39 Topic Next Topic: My Mechanical Adventures in HO Scale Motive Power
veets
Posted - 12/06/2019 :  3:48:30 PM  Show Profile  Reply with Quote
Greetings from a long-time lurker.
I came into procession of a number of Bowser Brill trolleys, all unpainted, in their original boxes. This was cool, because I had one when I was kid that I failed to complete, and which is long lost but fondly remembered.
The problem? I cleaned the shell of one and attempted priming it, first with Rust-Oleum etching primer, later with Badger's Stynylrez primer. Both failed to adhere to one part of the roof.
I'v stripped it down again with a good soaking in thinner, which removed the paint, but left the primer in the places it adhered to. Which is everywhere but that one part of the roof.
My next thought was a vinegar soak before another application of the Rust-Oleum. But before I do that, I wonder if any of you has any wisdom to share?
I'd post a photo, but I don't see the "insert a file" icon on my screen and the imaging posting button wants a URL.
(Moderator, please feel free to move this post, if I've wandered into the wrong sub-forum.)
Country: USA | Posts: 5
BurleyJim
Posted - 12/06/2019 :  4:17:45 PM  Show Profile  Reply with Quote
Hi Veets,
You might try rubbing the un-primered surface with some #600 grit wet/dry sandpaper to give that primer a little 'tooth' to adhere too. Go easy. you just want to break any glaze on the surface.
Country: USA | Posts: 5444 Go to Top of Page
SAFN SAAP
Posted - 12/06/2019 :  4:24:08 PM  Show Profile  Reply with Quote
Hey Veets,
Here is what I have done:
Get a brass brush from Lowes, Home Depot, or your hardware store. Work the casting with a file or a dremel bit to clear all the parting lines and flash. Once done, then take the brass brush and scrub it until the metal shines. Then give it a good vinegar bath undiluted, and then rinse with warm water. Then hit with the brass brush again. After everything is dry, prime with an oxide color. Some bake in the oven at a real low temp (125*) for 20 minutes. Then paint. You should have no adhesion problems.
Levi
Country: USA | Posts: 436 Go to Top of Page
Posted - 12/06/2019 :  4:26:26 PM  Show Profile  Reply with Quote
"prime with an oxide color" - using a solvent based paint, not an acrylic!
Country: USA | Posts: 8427 Go to Top of Page
veets
Posted - 12/06/2019 :  6:04:00 PM  Show Profile  Reply with Quote
So now I have a plan of attack. Thank you all for your advice. I'll let you know what I try and how I make out.
(I'm sure this has been asked a million times, but would anyone care to offer a link to a method for posting jpg from Chrome. I'm not a complete noob -- I've been on the Internet since before there was a www -- but I can't seem to get this. I did look at all of the FAQs, too. Thanks again!)
Country: USA | Posts: 5 Go to Top of Page
