Railroad Line Forums - Micro Adjuster for Mini Table Saw
[ Active Members: 4 | Anonymous Members: 0 | Guests: 62 ]  [ Total: 66 ]  [ Newest Member: crossbuck ]
 Startin' from Scratch
Author Previous Topic: Angels Reach Bridge Pt. 1 Topic Next Topic: Dewey Bros. oscillating cylinders steam loco
sn3forme
Posted - 09/17/2016 :  6:51:32 PM  Show Profile  Reply with Quote
I've been fooling around with a scatch build
of a D&WRG caboose in 1/20.3 scale. This scale
takes very large wood strips and I needed a way
to micro adjust my fence to make fine cuts.
I used my Balsawood strip cutter to make the
adjustments on my fence by removing the blade and
inserting a strait edge.
Hope this is useful.
Country: USA | Posts: 185
Reg Barron
Posted - 09/17/2016 :  8:04:41 PM  Show Profile  Reply with Quote
Is this an adjustable stop? Will it be used with a mitre gauge to cross cut strip wood to length?
I saw a similar idea on a PBS wood working show this morning. I believe they had a mitre gauge with an extended
Fence and a wood block clamped to it as a stop. They used a screw in the block to move the work piece in either direction with micro movements. I think the idea of using a threaded screw to make small adjustments is a good one. Another idea is to add or remove shims between the work piece and the stop block.
I also noted that you placed your stop ahead of the saw blade. That is a good idea also, since it prevents jam ups or
Potential kick backs
Glad you posted this idea.
Reg Barron
Country: USA | Posts: 217 Go to Top of Page
Posted - 09/17/2016 :  8:17:19 PM  Show Profile  Reply with Quote
I've looked at this a couple times and don't quite understand how it works. Could you show a piece of wood in place?
Country: USA | Posts: 8238 Go to Top of Page
Posted - 09/19/2016 :  11:46:40 AM  Show Profile  Reply with Quote
I also don't "get it". I would use a much finer saw blade for stripwood. Those coarse teeth will hack the thin pieces to death.
Country: USA | Posts: 6701 Go to Top of Page
sn3forme
Posted - 09/25/2016 :  12:20:42 PM  Show Profile  Reply with Quote
Sorry about the confusion, I should
have set the adjuster clamped to the
table saw behind the fence. You could
now creep up on the blade. As for the
blade, I have a fine tooth blade for
ripping strip but since I am building
a large scale caboose I left that blade
in.
Hope this clears things up.
Country: USA | Posts: 185 Go to Top of Page
sn3forme
Posted - 09/25/2016 :  12:26:35 PM  Show Profile  Reply with Quote
Sorry for the confusion.
I should have set the adjuster
clamped to the table saw behind
the fence so you could creep up
on the blade. As for the blade,
I do have a fine tooth blade for
ripping thin strip, but I have
been working on a large scale
caboose, so the strips are
much larger.
Hope this helps.
