Railroad Line Forums - Bachmann freight car lettering
[ Active Members: 4 | Anonymous Members: 0 | Guests: 88 ]  [ Total: 92 ]  [ Newest Member: AllanJSmith ]
Author Previous Topic: Bmann Porter Tank Replacement Question Topic Next Topic: On30 Mini Meet in Northern California April 27th
dougcoffey1950
Posted - 04/16/2013 :  07:18:01 AM  Show Profile  Visit dougcoffey1950's Homepage  Send dougcoffey1950 a Yahoo! Message  Reply with Quote
What works well for removing the lettering?
Country: Canada | Posts: 1009
elwoodblues
Posted - 04/16/2013 :  07:21:50 AM  Show Profile  Visit elwoodblues's Homepage  Send elwoodblues a Yahoo! Message  Reply with Quote
Good Question Doug, I know that this topic has come up before (probably numerous times) but I'm now at the stage where I have decals for my line and need to re-letter a few cars and locomotives. Bottom line is, I don't remember what the solution is and I would also like to know what works best.
http://cvry.ca
Country: Canada | Posts: 6446 Go to Top of Page
Posted - 04/16/2013 :  07:31:17 AM  Show Profile  Reply with Quote
Well...I got the idea ov using good ol "Pine Sol"
from Larry (Big_Lars) over in ON30 (The Dark Side)
Ju have filled a container (rip off one from the
stash in the cupboard) with pine-sol and let
the units sit in it for a while. Some cars take
longer than others. When you see the lettering
starting to crinkle or flake off, a toothbrush
will remove the rest. It has worked for me.
Just an idea.....
"You can find my Website & Threads here:"
http://www.railroad-line.com/forum/topic.asp?TOPIC_ID=47229
Posted - 04/16/2013 :  09:32:03 AM  Show Profile  Visit milocomarty's Homepage  Reply with Quote
Glasfiber brush..
Country: Netherlands | Posts: 6667 Go to Top of Page
Tommatthews
Posted - 04/16/2013 :  09:50:58 AM  Show Profile  Reply with Quote
"GoJo" hand cleaner. Test it first as I believe it may take the shine of the plastic around the area applied.
Tom M.
jcoop
Posted - 04/16/2013 :  1:51:56 PM  Show Profile  Reply with Quote
I have had luck with "easy lift off" available at your local hobby shop
Country: USA | Posts: 1405 Go to Top of Page
p51
Posted - 04/16/2013 :  2:52:53 PM  Show Profile  Visit p51's Homepage  Reply with Quote
I read somewhere that Sterno heating gel can soak off the lettering. I haven't tried it yet, I have a Bachmann 4-6-0 I need to remove locomotive numbers from and nothing else...
Country: USA | Posts: 35 Go to Top of Page
MinerFortyNiner
Posted - 04/16/2013 :  6:23:46 PM  Show Profile  Visit MinerFortyNiner's Homepage  Reply with Quote
Doug, I like to use a product called Gun Scrubber...it is a solvent cleaner for, well, you know...cleaning guns. Also works great on taking off the ink lettering used by Bachmann and other builders without destroying the original finish. I most recently used it to remove the dimensional data from some Bachmann 18' freight cars. Spray a little on a cotton swab over a leftover tin pie plate, dampen the lettering and then gently rub. If you take your time and go easy, and don't saturate the model with the solvent, the lettering will come off without any telltale abrasion or discoloring. Important: After wiping off the lettering, take a clean piece of cloth dampened with water and wipe where the solvent was applied to neutralize it. Works like a dream!
Country: USA | Posts: 2793 Go to Top of Page
