Railroad Line Forums - slow om curves
[ Active Members: 8 | Anonymous Members: 1 | Guests: 41 ]  [ Total: 50 ]  [ Newest Member: Speedy ]
 Small Scale Model Railroad Forum
 slow om curves
Author Topic Next Topic: The Z layout again
Dennis Perkins Sr
Posted - 06/23/2012 :  12:39:58 PM  Show Profile  Reply with Quote
After checking and rechecking. I noticed that a thrust washer #490115 was missing in front of the worm gear, I put a washer on each end of both worm gears...it worked for my Atlas SD60M
dennis p.
dennis p
Edited by - Dennis Perkins Sr on 05/22/2013 2:03:24 PM
Country: | Posts: 2
Posted - 06/23/2012 :  12:48:46 PM  Show Profile  Reply with Quote
It sounds like you may have one of the trucks binding or not turning far enough. I would turn the engine upside down and appling enough pressure to equal the appox. weight of the engine turn each truck back and forth to see if it does bind and has full range of movement. Being it continues to run I don't think you have a contact or electrical problem.
Country: USA | Posts: 10170 Go to Top of Page
Posted - 06/23/2012 :  1:10:09 PM  Show Profile  Reply with Quote
I have to admit when I saw the title all I could think of was Yoga or Hare Krishna :-)
But I think Mike's probably correct. Two other things to check: (1) make sure the wheelsets are in gauge (you could get binding like this if one wheelset is a little wide) and check the track gauge. For both all you need is an NMRA gauge, a good investment.
Edited by - deemery on 06/23/2012 8:13:16 PM
Country: USA | Posts: 3706 Go to Top of Page
Posted - 06/23/2012 :  7:59:28 PM  Show Profile  Reply with Quote
I also agree with what Mike has already stated. Do test the range of movement on the trucks, because it could be as simple as a pickup wire from the one side not long enough to make a good swing for that truck.
Country: USA | Posts: 11275 Go to Top of Page
djconway
Posted - 06/24/2012 :  10:55:45 AM  Show Profile  Reply with Quote
Also check that the worm and top gear are meshing properly. I don't have a SD60 but on all the Atlas locos that I have if you look at the truck from the bottom the slot for the gears goes to the right hand side.
Country: USA | Posts: 41 Go to Top of Page
Steam was generated in 0.19 seconds. Powered By: Snitz Forums 2000
