Railroad Line Forums - How to make a longer hex drive for Athearn/Kato
[ Active Members: 4 | Anonymous Members: 0 | Guests: 95 ]  [ Total: 99 ]  [ Newest Member: jmiller320 ]
 Shop Talk
 The Diesel Shop
Author Previous Topic: Norfolk Southern Heritage Units Topic Next Topic: Your favorite Fallen Flag line comp.!!
John Ryan
Posted - 05/06/2012 :  4:28:36 PM  Show Profile  Reply with Quote
After 3+ years of trying to run in an Athearn SD60, I'm going to remotor with a Kato... Everything is in, and fits well, except the Hex drives are about 1/8" too short. Has anyone run into this? and what can be done to fix this? I know NWSL has drives shafts, but nothing to fit that Athearn flywheel...
Country: | Posts: 13
Posted - 05/06/2012 :  4:51:03 PM  Show Profile  Reply with Quote
Kato makes a number of HO hex-drive universals in different lengths. Athearn pretty much copied their design, so they should fit. Kato's universals, as far as I know, are a perfect fit in Athearn's hex drive diesels. The ball should pop right into the Athearn coupling, and the hex head fits into the Athearn flywheels. They're also a more durable material. So, I would strongly recommend looking for the Kato universals to replace your too short Athearn drives.
Couldn't you just cut the drive and splice in an 1/8" inch piece and make it work?
Country: USA | Posts: 12729 Go to Top of Page
John Ryan
Posted - 05/06/2012 :  5:45:18 PM  Show Profile  Reply with Quote
I guess, but how do you glue the slippery plastic used?
Country: | Posts: 13 Go to Top of Page
railmus
Posted - 05/06/2012 :  7:41:26 PM  Show Profile  Visit railmus's Homepage  Reply with Quote
JUst a thought.
Cut the round portion of the axle and file both pieces square.
Press fit into square brass tubing.
Should be able to get any length you need. AC might help but shouldn't be necessary ???!!!
John Kanakos
CNJWS II, Custom Models- Design & Build
http://www.junctionwestsub.ca
NMRA #055691 CARM # 212
Country: Canada | Posts: 1743 Go to Top of Page
Steam was generated in 0.24 seconds. Powered By: Snitz Forums 2000
