| Author |
Topic  |
Schoolmaster
Posted - 03/08/2012 : 1:42:02 PM
The basic plans are from the Santa Fe railroad standard structure plans. I'm modifying them to use the lumber sizes and types I have.
It's a solar day, in this case from 11:00 am to 11:00 am the next day.
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/08/2012 : 2:06:36 PM
Step 6: Walls and framing.
More office offcuts and siding from the warehouse.
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/08/2012 : 4:48:16 PM
Step 6: more walls and framing.
I ran out of stuff and had to change techniques because it was too slow.
Made from lots of bits and pieces of siding from the warehouse and hotel.
Painted some things too. Green is the inside, red is the outside, white is the trim.
Edited by - Schoolmaster on 03/08/2012 4:49:03 PM |
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/08/2012 : 5:49:42 PM
Step 7: Raising the walls.
I'm using the doors from the Bar Mills kit to help hold things square.
The building will be made in two main parts that slot together at the end so that I maintain access to all the areas to put in details.
The doors came off the Bar Mills #1 kit, I had 6 spare and used 4 in this structure.
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/08/2012 : 6:29:22 PM
Step 7: Raising the walls (and fitting in the door headers)
Edited by - Schoolmaster on 03/08/2012 9:02:15 PM |
Country: USA
| Posts: 1581 |
Posted - 03/08/2012 : 6:30:34 PM
John, Keep going it looks good.
Country: USA
| Posts: 7367 |
Schoolmaster
Posted - 03/08/2012 : 7:23:21 PM
Step 8: Stalls
It's much easier to build the frames around the stall doors than to frame out the openings and hope. The stalls are only 3/4" wide so it's hard to reach in too. Paint next and make the stall 'fittings' while the paint dries.
Edited by - Schoolmaster on 03/08/2012 9:02:50 PM |
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/08/2012 : 9:01:07 PM
Step 8: Stalls
The fittings are mostly complete. Even LP men forget to put the seat down.
Made from scraps of pier bents and warehouse office.
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/08/2012 : 9:25:58 PM
Step 9: Trim
Inside door trim.
came with Bar Mills #1 doors.
Wall cap trim
Edited by - Schoolmaster on 03/08/2012 9:27:51 PM |
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/08/2012 : 10:02:09 PM
Step 9: Trim (and details)
Urinal
found a piece of truss rod from the wearehouse for the pipe and the urinal is made from a piece of leftover 1:24 corrugated metal made from Coke cans with a paper crimper.
Step 10 Assembly
Here are the two units for final glueing
Glue and clamp.
Enough for tonight. It will take a couple of hours for the glue to dry solid. Tomorrow morning I need to finish the roof and make the signs. I'll cut the tar roof, make the rafters and sheathing and the signs before I go to bed. Tomorrow it's final assembly.
Edited by - Schoolmaster on 03/08/2012 10:04:56 PM |
Country: USA
| Posts: 1581 |
Schoolmaster
Posted - 03/09/2012 : 08:05:11 AM
Back at work, about 3 hours to go.
Country: USA
| Posts: 1581 |
Posted - 03/09/2012 : 08:20:49 AM
looking great john, ive been following along
Country: United Kingdom
| Posts: 3880 |
Schoolmaster
Posted - 03/09/2012 : 08:40:31 AM
looking great john. How about great looking john,john Thanks andy.
The glueing of the main structure went well.
Step 10:Roof
Glue the sheathing
then the rafters
and the roof beam (notched with a motor tool)
Country: USA
| Posts: 1581 |
elwoodblues
Posted - 03/09/2012 : 08:47:25 AM
John,
Looking good and your almost there. (I bet the picture taking and posting is taking longer than the actual build itself)
Ron Newby General Manager Clearwater Valley Railway Co. http://www.cvry.ca |
Country: Canada
| Posts: 4874 |
Posted - 03/09/2012 : 08:57:53 AM
Step 10:Roof
Glue the sheathing
then the rafters
what can i say, im complamentry
| Posts: 3880 |
Topic  |
