Railroad Line Forums - Notes from the CSS07 Clinics
[ Active Members: 17 | Anonymous Members: 0 | Guests: 33 ]  [ Total: 50 ]  [ Newest Member: hepkat63 ]
 Mike Chamber's Craftsman's Corner
Author Previous Topic: Corrugated roofing question Topic Next Topic: Color of Water in Water Tank
Page: of 3
rsmilley
Posted - 11/06/2007 :  7:30:56 PM  Show Profile  Reply with Quote
Hi All,
I really hope these notes are helpful for everyone... I didn't take notes in EVERY clinic, but I did my best to jot down info about materials & colors & formulas & process steps.
As you can see, each of our clinicians tends to have their own "techniques". I think this has been one of the mysteries to me that is now solved - there is not just "ONE way" or a "BEST way" to do things in this hobby. The cool thing is that we got to see and/or hear about a variety of methods to do the same thing; now we can each try them out on our own and find the one that works best for us.
So I've included my notes in three formats:
1) cut & paste below into this posting.
2) attached as a MS Word file.
3) attached as a .txt file.
I imagine there are many others who attended the show who may be able to supplement and/or correct my notes. Please feel free to add more info to this thread... I'll be cutting and pasting any additional notes into my own running list.
Painting & Weathering Wood Walls - with Bob Mitchell
Some suggested materials:
Peeling Paint:
- Windsor & Newton – Art Masking Fluid: Apply w/sponge or stipple w/cheap brush.
good Weathering Paints:- WalMart paints
- Folk Art Paints: Light Oxide Red, Terra Cotta, Linen (great for concrete)
good Paints for Windows & Detail Castings:
- Tamiya paints; for priming – tan, gray, brown (color codes: AS-15, AS-22, AS-4)
good Brick Mortor Paint:
- Tempurpaint
good Etchant solution:
- Rio Grande
- did NOT recommend Woodland Scenics etchant
good Weathering Powders:
- Sierra Scale Models (mix w/alchohol)
- Bragdon Powders
- Rustall (this is the only 1 that is especially unique in the set)
good Glues:
- Carpenters Glue or thick CA (for attaching Metal Castings to Wood)
- Canopy Glue
- Aleene’s Sticky Glue
- Wellbond Glue
Some suggested painting processes:
Wood Walls:
Step 1: A&I stain on both sides (or similar) (allow to dry)
Step 2: prep for peeling paint as desired (allow to dry)
Step 3: dry brush / stipple with desired wall color (2-3 shades of desired color) (allow to dry)
Step 4: distress wood; add nail holes, broken ends, etc as desired
Step 5: A&I wash over top of dried, distressed wood (allow to dry)
Step 6: dry brush w/light colors – paint and/or chalks
Brick Walls (plaster):
Step 1: light matte finish (allow to dry)
Step 2: apply red color (allow to dry)
Step 3: apply mortar color wash (allow to dry)
Step 4: add weathering colors / chalks as desired (allow to dry)
Step 5: add final matte finish (allow to dry)
Masonry Walls (plaster):
Step 2: apply tan & brown colors (individual stones) (allow to dry)
Step 3: turpentine + oil-based paints for weathering (very diluted browns & blacks) (allow to dry)
Step 4: add final matte finish (allow to dry)
Tissue Paper (good for rolled tar-paper roofs, tarps, etc):
Step 1: paint or spray paint w/ brown or black paints (allow to dry)
Step 2: dry brush (carefully) (allow to dry)
Step 3: cut to size or strips
Step 4: apply to location with diluted carpenters glue
Alternative Materials - with Bob Mitchell
- PrismaColor Markers - good for painting & weathering wood
- DecoColor Markers - good for painting sides of rails & ties
- Figma Micron Markers - good weathering markers (brush or pencil versions)
- Kneaded Artist Eraser - absorbs graphite
- Sponges - rubber cement pickup sponge – picks up rubber cement for peeling paint
- Sierra Scale Models – weathering powders
- Detail Enhancer – Testors #2790
- Tamiya Finishing Abrasive – for track cleaning (800 or 1000)
- Glues: G.S. Hypo Cement, Walthers Goo, Crafters Pick
Board by Board Construction - with Brett Gallant
Wood Walls – General Painting & Weathering Prep Process:
Step 1: Stain wood
Step 2: Add texture
Step 3: Add details
Formula for Wood Base Stain:
- 20 oz of water
- ½ teaspoon of India Ink (water-soluble version)
- 1 teaspoon of PollyScale Roof Brown
- 1 teaspoon of PollyScale Oily Black
- 1-¼ teaspoon PollyScale RR Tie Brown
Process for Staining Wood:
- Soak wood in small tub or plastic zip-lock baggie for range of time from 6 to 24 hours – to get a variety of color.
- Shake/ mix periodically.
- Allow to dry on paper towel.
Advanced Techniques - with Brian Nolan
- fill an empty 1oz bottle w/mineral spirits – nearly to the top (90% full)
- add 4.5% of Floquil Grime color
- add 4.5% of Floquil Earth color
- add just a touch (1 %) of Floquil Roof Brown color
Step 1: Stain wood w/above formula (allow to dry)
Step 2: Add texture w/wire brush
Step 3: Use Bragdon Powders (brown) to get into grain of wood (sometimes wash w/mineral spirits) (allow to dry)
Step 4: Dry Brush w/ earth tones (country tan, driftwood, grays - darker colors first, then lighter colors) (allow to dry between layers of different color)
Formula for Stone-Work Base Stain:
- w/mineral spirits, mix a few drops of paint (make a separate stain solution for each):
Testors ModelMaster enamal paints: wood, light gull gray, military brown
Makes a very light, transparent stain; apply multiple coats of layered paint
Stone-Work (plaster) – General Painting & Weathering Prep Process:
Step 1: Stain rocks w/above stains (allow to dry between each layer; color individual stones w/different colors)
Step 2: When dry, apply mortar lines: very fine misting of wet water over entire casting (just enough to get into mortar lines; apply thinned PollyScale Roof Brown wash into mortar lines.
Creating Peeling Paint Affect on Wood Walls:
Step 1: Wet w/mineral Spirits
Step 2: Apply acrylic paint (PollyScale water-based) w/’shader brush”; allow to absorb into wood, but not fully dry.
Step 3: Using #11 xacto blade point, add some wood grains.
Step 4: Allow to dry slightly, with #11 xacto blade point, scrape / peel away some of the globs of paint collecting over the mineral spirits.
Step 4: Allow to completely dry, apply A&I wash.
Download Attachment: css07_ClinicsNotes.doc
32.26 KB
Download Attachment: css07_ClinicsNotes.txt
5.79 KB
Country: USA | Posts: 349
onl26
Posted - 11/06/2007 :  7:59:49 PM  Show Profile  Reply with Quote
Hey Steve
Great idea, thanks for putting all these notes in one place.
Kevin
Country: USA | Posts: 951 Go to Top of Page
Peterpools
Posted - 11/06/2007 :  8:23:04 PM  Show Profile  Visit Peterpools's Homepage  Reply with Quote
Steve
Thanks for posting all the information as a MS Word File. I've downloaded and saved the files.
Country: USA | Posts: 12301 Go to Top of Page
simon1966
Posted - 11/06/2007 :  8:27:24 PM  Show Profile  Visit simon1966's Homepage  Reply with Quote
Steve, a great idea, thanks. I was struggling to read some of my notes made in the dark and this has provided some much needed clarity.
Simon
Modelling CB&Q and Wabash
See my slowly evolving layout on my picturetrail site
http://www.picturetrail.com/simontrains
Country: USA | Posts: 2245 Go to Top of Page
KVRailfan
Posted - 11/06/2007 :  8:47:04 PM  Show Profile  Visit KVRailfan's Homepage  Reply with Quote
Great Steve, this is a big help .
Sreve
Country: Canada | Posts: 779 Go to Top of Page
Ken Hamilton
Posted - 11/06/2007 :  9:09:14 PM  Show Profile  Visit Ken Hamilton's Homepage  Reply with Quote
Great notes!
Thanks for documenting all that info, Steve.
It's a big help (...especially for those of us who didn't take notes....)
Ken Hamilton
www.wildharemodels.com
http://public.fotki.com/khamilton/models/
Country: | Posts: 919 Go to Top of Page
kay4pacific
Posted - 11/06/2007 :  10:28:21 PM  Show Profile  Reply with Quote
Steve,
I'm sure everyone is very thankful for your notes. Seeing I was unable to attend the seminars, this is a great help. Kudos are very much in order. TY.
Cape Cod
Country: USA | Posts: 4735 Go to Top of Page
Jerry M
Posted - 11/06/2007 :  11:03:26 PM  Show Profile  Reply with Quote
Got it and thank you, very considerate of you to share...
Logging the Great Northwest in On30
Country: USA | Posts: 3913 Go to Top of Page
bruno
Posted - 11/07/2007 :  12:54:15 AM  Show Profile  Click to see bruno's MSN Messenger address  Reply with Quote
THANK YOU STEEVE. THIS IS THE REASON WHY I LOVE THIS SITE. INFO IS SHARE.THIS WILL BE HELPFUL TO A LOT OF US.SPECIALY TO ME,AN AMATEUR.AND NEW WAYS TO BUILD.
YVES
Country: Canada | Posts: 158 Go to Top of Page
Posted - 11/07/2007 :  06:39:05 AM  Show Profile  Reply with Quote
Thanks Steve. I wasn't able to attend a single seminar, so this is very helpful.
___________________________________
All the things that others want for me...
Can't buy what I want because it's free...
Country: USA | Posts: 12134 Go to Top of Page
slimjerkins
Posted - 11/07/2007 :  06:41:32 AM  Show Profile  Reply with Quote
Thanks Steve
Great job. I'm nominating you for the recording secretary spot.
-slim
Country: USA | Posts: 1114 Go to Top of Page
Old Fogy
Posted - 11/07/2007 :  07:12:20 AM  Show Profile  Reply with Quote
Very thoughtful of you, Steve, to post this info. Thank you.
"In our Country...one class of men makes war and leaves another to fight it out."
Gen. William T. Sherman
Country: USA | Posts: 624 Go to Top of Page
Danny Head
Posted - 11/07/2007 :  07:57:37 AM  Show Profile  Reply with Quote
Steve...... YOU are the man! Thanks so much. This is extremely thoughtful and will go in my file. I will start trying some of these methods right away. The folks in this forum are the best. Danny Head Guntersville, Al.
Country: USA | Posts: 1422 Go to Top of Page
BrianZ
Posted - 11/07/2007 :  08:05:29 AM  Show Profile  Reply with Quote
Thanks Steve, great notes!
Brian Zessin
Country: USA | Posts: 174 Go to Top of Page
PaulS
Posted - 11/07/2007 :  09:09:29 AM  Show Profile  Reply with Quote
Steve,
Very nice to meet you at the show and thanks so much for posting the notes from the clinics. I did not attend all of them and your notes are far better than the ones I took from those I attended....
Thanks again, much appreciated,
Paul S.
Modeling the Atlantic & White Mountain Railway
Country: USA | Posts: 662 Go to Top of Page
JohnJ
Posted - 11/07/2007 :  09:21:43 AM  Show Profile  Reply with Quote
Steve: Thanks for sharing your notes. Really helpful for those of us who could not attend.
John Johnson
MY SECOND CHILDHOOD IS SO MUCH MORE FUN THAN MY FIRST!
Country: USA | Posts: 1020 Go to Top of Page
Page: of 3 Previous Topic: Corrugated roofing question Topic Next Topic: Color of Water in Water Tank
Railroad Line Forums © 2000-10 Railroad Line Co. Go To Top Of Page
Steam was generated in 0.92 seconds. Powered By: Snitz Forums 2000
