[ Active Members: 1 | Anonymous Members: 0 | Guests: 199 ]  [ Total: 200 ]  [ Newest Member: mm0047 ]
 HOn30 and HOn3 Forum
 Scratchbuilt HOn30 Monson flats
deemery Posted - 06/15/2015 : 4:14:08 PM
Here's the first flat I built using a set of jigs that I'll describe in the next couple of days.
The bracing for the car ends is (code 40) rail, just like the prototype. It's a good reason to keep those snippets of rail from track laying.
deemery Posted - 06/21/2015 : 5:52:58 PM
This photo shows the difference between Jeff's "scale" stake pockets and Tichy/Grandt stake pockets. (I think these are Grandt, but both Grandt and Tichy pockets are a lot bigger.)
jnj1097 Posted - 06/20/2015 : 11:03:06 PM
Originally posted by jschumaker
I looked for PSC's brake gear and pawl on their website. It is not listed on their price list.
Jeff S
Call or E-mail and give them the part number for the plastic or brass part and see if they have them in stock.
I purchased the lot I have years ago, but they should still have them as part of their line.
Jeff
jschumaker Posted - 06/20/2015 : 9:12:48 PM
Jeff S
jnj1097 Posted - 06/20/2015 : 11:31:02 AM
What's the difference between the Grandt Line stake pockets and the printed ones you used? Grandt has both single and double u-bolt variants. I find the Tichy stake pockets a little too robust for my taste; look too modern.
The printed parts will fit inside the Grandt Line single u-bolt stake pocket. The Grandt parts are grossly oversize for HO, and even S. Perfect for On2 though...
Jeff
Michael Hohn Posted - 06/20/2015 : 10:54:12 AM
I generally use the Tichy parts after a little surgery. I end up with all these short pieces of brass wire because I find the Tichy part to be a little oversize in diameter for my period. Picky, picky, picky.
deemery Posted - 06/20/2015 : 10:27:22 AM
Thanks! It's similar to the pawl that Tichy sells, then: https://www.tichytraingroup.com/Shop/tabid/91/c/brake-gear/p/3003/Default.aspx
jnj1097 Posted - 06/20/2015 : 10:19:32 AM
Originally posted by deemery
Jeff, what's the PSC part number for the ratchet/pawl you use? Could you post a photo of one?
Here's a few pictures Dave...
Styrene (left) and brass versions of the parts. They come in a four pack.
This photo shows one installed on an HOn2 WW&F flat car.
Jeff
jschumaker Posted - 06/19/2015 : 3:41:53 PM
Dave,
For brake wheels, I have use laser cut ones from Mt. Blue. He is willing to sell them separately. You can contact him through his website.
Jeff S.
deemery Posted - 06/19/2015 : 2:57:56 PM
jnj1097 Posted - 06/19/2015 : 2:45:45 PM
Thanks for designing them, including optimizing the sprue to get the best 'bang for the buck' from Shapeways.
Here's a suggestion for a project: Brake ratchet and pawl. I used a Tichy part on my build, but it looks a bit oversized. (You can see it on my completed kit at the top of Page 1.) Also, an assortment of brake wheels would be useful. Finally, a variation on the stake pockets with stakes (either finished lumber or 'sticks' as were used on the Monson) might be useful.
Not a problem Dave, glad to see someone using them. I recently had some more printed in FXD and they look a little nicer/less coarse.
I use ratchet/pawl castings from PSC. They are available in a four-pack in either brass or styrene. I have over 50pkgs of them, so there's no need for me to do a ratchet/pawl, and IMO, the PSC parts will look better than any 3D printed one anyway.
Brake wheels would be too fragile in printed material. I use a Cal-Scale part (brass) for those.
Stake pockets with stakes are doable and not very difficult to do.
In addition to the stake pockets, I've also done body bolsters, and diamond arch bar trucks. I don't sell them because both require secondary operations using tools that most modelers don't have or won't purchase. The trucks use the same wheels you use for your Grandt trucks (0.540" axle).
Jeff
deemery Posted - 06/18/2015 : 09:50:57 AM
I'm using Fox Valley N scale, wide tread, 36" wheelsets. They are a little loose in the Grandt trucks, but then so are the wheelsets that Grandt included in some of the truck sets I have. One difference is the Grandt wheelsets have square axles, while the Fox Valley trucks have the more common pointed axles. The stake pockets are 3D printed from Shapeways: https://www.shapeways.com/product/CBENXBEHH?optionId=42783127&li=ostatus
I thought the stake pockets looked familiar... They are mine! I'm glad that they are getting used by someone.
Thanks for the information Dave. It looks great.
Jeff
Thanks for designing them, including optimizing the sprue to get the best 'bang for the buck' from Shapeways. The stake pockets are easier to see in this photo:
jschumaker Posted - 06/18/2015 : 09:27:49 AM
Excellent jig, Dave.
Jeff S.
jnj1097 Posted - 06/18/2015 : 09:26:58 AM
Jeff
deemery Posted - 06/17/2015 : 10:51:45 AM
Same jig would work for house cars, in fact I think Monson had some boxcars built on flatcar frames. For most boxcars, you'd have to adjust the size of things to account for the external sheaving.
Michael Hohn Posted - 06/17/2015 : 10:46:44 AM
Dave,
Nice looking car. I've long thought those two-foot flats were pretty cool with the end stakes sticking up through the floor. When I did a bunch of flats a couple of decades ago I did a couple with stakes like that, but in standard gauge. I've since decided that was pretty rare in standard gauge so they are not at all accurate. Still, they are part of my MOW string of cars; I use them for ties.
I'll have to remember your jig next time I build some flats.
Good job all around.
