[ Active Members: 6 | Anonymous Members: 0 | Guests: 145 ]  [ Total: 151 ]  [ Newest Member: lewisoliver ]
 Small Industrial Rolling Stock
acousticco Posted - 10/14/2013 : 5:24:06 PM
I mentioned that I fell of the non-On30-wagon by ordering a tiny 0-4-0WT :
http://www.railroad-line.com/forum/topic.asp?TOPIC_ID=41046
I went another step over this morning and built an even smaller four-wheel car for it to pull:
It's only about four feet wide by seven feet long. The journal boxes are cut from a Titchy archbar truck with Kadee HO 28" wheelsets, which works out to about 14 inches in O scale, the rest is the usual Brass bits and Grandt Line NBWs. Coupling will be simple link & pin, chains or drawbars and will be installed later. So far, I quite like it.
It looks allot like a kit made my Aru Models:
http://homepage3.nifty.com/arumo/r0031.htm
But I like the individual board wood construction method better in O scale.
-Cody
Pacbelt Posted - 11/08/2013 : 02:50:58 AM
Originally posted by ironflyer
NBW's look better than plain old rivets
Nice work Cody!
THAT'S FOR SURE!!!
ironflyer Posted - 11/08/2013 : 02:40:49 AM
Nice work Cody!
Pacbelt Posted - 11/08/2013 : 02:08:24 AM
Wait a moment.....
You don't want to be accused of Rivet Counting in On30 - do you!!???
Seriously, that Really came out great!!
acousticco Posted - 11/07/2013 : 11:20:05 PM
Oh! There is no planking over the bottom strap bolts! Good catch, looks like I'll be installing some carriage bolt heads shortly.
acousticco Posted - 11/07/2013 : 11:15:03 PM
Prototype practice? Beats me. My story is that they're carriage bolts and the heads are hidden by the planking, same with the ones holding the coupler bar to the underside.
-Cody
Neil M Posted - 11/07/2013 : 10:14:02 PM
If I were to be nitpicking I would ask what happens to the NBWs that you put on the bottom of the straps once they are in the wood? Should there be a nut on the top of the timber over the NBW or do the bolts screw into the wood? (Seriously, what was the prototype practice here?)
BigLars Posted - 11/07/2013 : 8:59:32 PM
I was going to try some kadee HO log bunks to make cars to carry support beams into the mine. Small mow cars would be interesting.
acousticco Posted - 11/06/2013 : 5:53:15 PM
Originally posted by BigLars
Cody,
I built up a bunch of the left over cars from grand it line parts and they are at the stage your cars are at. I will be watching you for ideas.
Larry, I'm not sure what these will be yet but I'm thinking some kind of MOW cars...
-Cody
acousticco Posted - 11/06/2013 : 5:50:41 PM
Originally posted by lenelg
"I think the Porter would dwarf this car"
Why build a tiny prototype and then try to disguise its tininess? ;^)
Don't worry, there will be some people, automobiles and equipment around to make the trains tininess pretty obvious. I want the engines dwarfed by the scenery as well.
-Cody
BigLars Posted - 11/06/2013 : 07:19:58 AM
Cody,
lenelg Posted - 11/06/2013 : 02:06:53 AM
acousticco Posted - 11/06/2013 : 12:37:50 AM
Thanks Folks!
I think the Porter would dwarf this car, it looks okay with a Grandt Line HO scale GE 25 ton diesel, of which I have one formerly HOn30 gauge and recently switched to16.5mm gauge, (and running quite nicely)... Maybe a small diesel will be in the works for my On30 line one day...
-Cody
Tommatthews Posted - 11/03/2013 : 09:30:46 AM
Nice, interesting work Cody.
Geezer Posted - 11/03/2013 : 09:14:48 AM
Neat flat car....would be good behind a
Porter as well....maybe tool box etc....
Nice work!
Frederic Testard Posted - 11/02/2013 : 8:19:57 PM
Fine looking models, Cody.
