[ Active Members: 4 | Anonymous Members: 0 | Guests: 41 ]  [ Total: 45 ]  [ Newest Member: On30aud ]
 Mrs. Schnebley's Sauerkraut
LaRueD Posted - 12/09/2011 : 10:18:57 PM
Hello crew,
I am posting my current progress on a HO-scale scratch build based on Earl Smallshaw's classic "Perkins Produce" (below). The article, including scale drawings and color signs, appeared in the December, 1974, issue of Model Railroader magazine.
While Earl's original design yields a great structure, I had a few ideas of my own I wanted to incorporate as well as some construction techniques I had been wanting to try.
First of all, the clapboards were constructed using individual strips of 140lb Strathmore acid-free watercolor (WC) paper applied to a base of 1/16th taskboard.
Upon completion of the walls, they were base-colored using Pollyscale "Earth" and Americana "Mississippi Mud" for the windows, doors (all Tichy), and misc. trim. Each wall was then given washes of Winsor & Newton "Burnt Umber" and "Payne's Gray" watercolors. This gave the overall structure a warmer, golden tone. The slight smattering of Payne's simulated dirt acumulation and subtle mold. Selected areas were dry-brushed (highlighted) using Americana "Driftwood" and/or Faber-Castell Polychromos color pencils (grays, browns).
Earl's roof was constructed of diamond-shaped shingles that he made using pinking-shears. I have followed suit using pinking shears (Michaels, $1.99 USD) and Stoney Creek Designs' rolled roofing in red (to my eye, more of a rust-color). The paper is meant to simulate the characteristics of real asphalt rolled roofing, and upon close scrutiny, has a subtle granular texture. Each "pink" scales to approximately 15-scale inches.
The "Mrs. Schnebly's Sauerkraut" sign is my own creation using Adobe Photoshop.
The basement is constructed of foam-core. The exposed brick portion was made by exposing one side of the board and scribing the brick courses using an x-acto blade - per Don Railton's technique. Once the brick mortar lines had been scribed, the brick area was base coated with appropriate brick colors. After drying over night, a thin coating of all-purpose drywall mud was applied using a flat painter's tool. This was allowed to dry thoroughly. Any high spots were sanded. Then using a dental pick, I began removing the dried drywall mud where I wanted to expose the brick beneath. Washes of Payne's Grey, and Bragdon weathering powders were used to blend everything together.
Continuation of the brick along the front elevation isn't necessary because the future grade (as per Earl's photo above) will cover most the basement/exposed brick. There will also be an open stair case extending from the front entrance down to the lower basement entrance.
I plan to expand on Earl's design where the adjoining shed/garage is connected to the basement. A larger structure to accommodate the necessary vats and curing tanks including plumbing and vent stacks.
Continued ...
Delbert
Sulphur Springs Valley, Arizona
LaRueD Posted - 03/15/2013 : 8:21:24 PM
LaRueD Posted - 03/09/2013 : 12:20:46 PM
Thanks, Denny.
Actually, I have no interest in building a model railroad. I just enjoy building scale structures as a creative outlet and temporary distraction from my entomological research and pursuits. I'll probably donate everything in time.
Retire? Me?
The Durango kit pops up once in a while on Ebay but at inflated price(s) just for a box of basswood, plastic and cardboard.
I wanted to compliment you on your website. Good information, .pdfs, and photography. I had visited it earlier in the week.
Thank you for your interest and views of my project.
Delbert
Sulphur Springs Valley, AZ
LaRueD Posted - 03/09/2013 : 12:11:19 PM
Thanks, Dave.
As it has been a while since I've spent any time at the modeling bench, I thought I would tackle a relatively straight forward project in hopes of getting back up to modeling speed.
Thanks for your comment and continued encouragement.
Delbert
CWRailman Posted - 03/09/2013 : 12:07:51 PM
Great build! Thanks for taking the time to document it and share. I also remember that original construction article and of course the kit it inspired that was issued by Durango Press. I’ve got that kit. I like the irregular board look of your model.
By the way, if you invest money in kits and supplies when you are working and don’t have the time to build then when you retire or are downsized into early retirement, you will have all the resources and time to build without spending money. And if you have a few extra kits etc you can sell them off to buy the things you overlooked or could not stock up on such as beer and pizza or wood, screws and glue to build that layout you dreamed of building.
Denny
Janitor in Training
CW Loco and Car Rebuild Shops
WEB site: http://www.cwrailman.com/Facebook: CWRailman
Dave S Posted - 03/09/2013 : 09:26:10 AM
Delbert,
I'll be following your continued adventure on this structure. I got so focused on your other build that I had totally forgotten about this one.
Later, Dave S Tucson, AZ
LaRueD Posted - 03/09/2013 : 12:18:37 AM
LaRueD Posted - 03/07/2013 : 5:48:11 PM
UPDATED: MARCH 07, 2013
This became a shelf orphan because I wasn't happy with how the scratch-build was progressing. Although the diamond-shaped shingled roofing compliments the structure, I didn't care for the material I had used. I felt by hand-cutting my shingles with craft scissors, the edges and profile weren't as crisp as I preferred. So perhaps some commercial shingles may be in order. I have stripped the structure down to just the walls and removed the roof and basement - which I also didn't like. I've also modified the large iconic sign, included below.
The pre-soldered chip LED(s) are from Evan Designs: http://www.modeltrainsoftware.com/
For 1/87 scale, I reduced the sign to 35%.
continued ...
Delbert
LaRueD Posted - 01/23/2012 : 7:44:00 PM
Originally posted by Ensign
Hi Delbert,I love the looks of this entrance where your brother in law seems to be enjoying a cold one.
Perhaps, if he were to put that bottle down & give you a hand, your worries about finishing this challenge in time would be put to rest.
Keep at it!
Thanks, Greg.
Delbert
Ensign Posted - 01/22/2012 : 11:45:30 AM
Keep at it!
LaRueD Posted - 01/22/2012 : 01:08:51 AM
... the brother-in-law ...
I managed to get some of the decking and front entrance stairs completed today. More later ...
Delbert
LaRueD Posted - 01/20/2012 : 7:59:07 PM
Originally posted by LaRueD
[quote]Originally posted by Dave S.
Delbert,
Congratulations on your promotion. I am reminded of what someone on one of the forums I read said recently. When you are working you have the money to spend but lack the time you need to complete all the models you'd like to. When you have the time to build all the models you want to you hearts content you lack the funds necessary to do so. Life is an enigma!
You are on a roll. Keep the forward momentum going! Good to see some more progress on the structure. What did you decide for the lower level structure? Have you abandoned the stucco covered walls for that level?
Later, Dave S. Tucson, AZ
Thanks, Dave.
Upon reflection, I am thinking the stucco/brick foundation may not be the best choice here. I hope to depict a small business/factory with attached sauerkraut/pickle curing tanks and processing structure as well as a shipping/loading area. The latter (probably) will replace the original stucco/brick foundation.
Thanks again for your positive comments and encouragement.
Thanks, Arthur.
Glad to hear your approval of my build thus far. I hope I can complete it before the 2-month deadline.
As always,
Best wishes, ...
Delbert
CieloVistaRy Posted - 01/20/2012 : 12:02:08 AM
Thanks for bumping this thread up. What a great build!
Dave S Posted - 01/19/2012 : 9:20:25 PM
Delbert,
LaRueD Posted - 01/19/2012 : 12:58:01 PM
**UPDATE: I have included this scratchbuild in the 10th Anniversary 2-Month Challenge thread**
Gentlemen, sorry for the delay. Many thanks for your comments. A promotion at work has limited my bench time in recent months. However, here are a few progress photos ...
*I made some changes to the roof peak and plan on adding a ventilation dormer so the roof peak shingling is incomplete*
Best wishes,
Delbert
brownbr Posted - 12/11/2011 : 07:52:28 AM
Nice work. Great technique on the brickwork. Like the way the sign clings to the wall.
