 Kit built Swedish H3 locomotive in brass
Page: of 3
Graffen
Posted - 07/02/2012 :  3:19:57 PM  Show Profile  Visit Graffen's Homepage  Reply with Quote
Hi all, this is one of my latest builds, a HO scale H3 locomotive built from a etched kit from SMJ/dekaler & etsat in Sweden.
The drive line is totally compensated with levers, and it works wonderfully.
I will paint it tomorrow, so this is the last pics of it in bare brass.....
Not the best pics, but I will take some more before painting it.
The satisfaction that is felt after building a brass loco is great!
Swedish custom painter
Graffen
Posted - 07/02/2012 :  3:22:22 PM  Show Profile  Visit Graffen's Homepage  Reply with Quote
The last pic disappeared.... :-)
Posted - 07/02/2012 :  3:43:17 PM  Show Profile  Reply with Quote
nicely done.
It's Only Make Believe
Bob Harris
Posted - 07/02/2012 :  8:32:12 PM  Show Profile  Reply with Quote
Very impressive work, Michael.[:-thumbu]
Posted - 07/02/2012 :  9:01:30 PM  Show Profile  Reply with Quote
Very nice engine!
masonamerican
Posted - 07/03/2012 :  01:37:57 AM  Show Profile  Reply with Quote
Congrats on the achievement[:-thumbu][:-thumbu]
I'm dreaming of building PERLS Cc engine. Wish I would dare tackle such a project.
Håkan
Edited by - masonamerican on 07/03/2012 01:48:40 AM
Graffen
Posted - 07/03/2012 :  1:23:52 PM  Show Profile  Visit Graffen's Homepage  Reply with Quote
Thanks all!
Håkan, go for it! The Cc is a very nice piece of kit. Just read the articles in "Modelltåg" by Claes Mattison.....
Good way to avoid some traps in the construction.....
Here are some better pics:
masonamerican
Posted - 07/04/2012 :  09:08:30 AM  Show Profile  Reply with Quote
Thank you for the tip! I'm a newbie to kit soldering but with the help of the articles perhaps I can pull it through. I'm trying to build a HNJ verkstad ABo sleeping car which is nearly finished. I have to have something to pull it with
Do you solder with an iron or do you use resistance soldering?
Håkan
Graffen
Posted - 07/04/2012 :  11:40:41 AM  Show Profile  Visit Graffen's Homepage  Reply with Quote
I use a Weller soldering station (100-450° C), it is very nice to use.
Resistance soldering might have it's followers, but I get the results I need without that.... :-)
They are not good for larger areas or soldering small items to thick goods.....there is a risk of burning thru as I understand it.
They are very good to have if soldering small items next to each other. I saw a signal bridge being soldered together with a resistance unit, and that is where it excels!
masonamerican
Posted - 07/04/2012 :  2:01:04 PM  Show Profile  Reply with Quote
Thank you for the info. I have a also a Weller. Model PU81 80w 150-450degC. Would it be enough for the job?
Håkan
Graffen
Posted - 07/04/2012 :  5:21:54 PM  Show Profile  Visit Graffen's Homepage  Reply with Quote
More than enough!
Remember to use Phosphorus acid as soldering water. It is so much better than other stuff!
Invest in some wide soldering tips though, they are really needed when soldering locos!
A small butane torch for annealing and heating big areas is also nice to have.....
Posted - 07/05/2012 :  02:48:22 AM  Show Profile  Reply with Quote
There's been some mighty impressive brass work done in Sweden these past days. Fantastic work, Michael, on a loco apparently very well designed by the kit manufacturer.
Posted - 07/05/2012 :  04:26:32 AM  Show Profile  Reply with Quote
That looks like a very well executed build. Does the rod from the front axle form part of the valve gear?
Could you post a picture of the bottom of the chassis? I always like seeing the workings of a compensated chassis.
Graffen
Posted - 07/05/2012 :  05:42:25 AM  Show Profile  Visit Graffen's Homepage  Reply with Quote
Thanks!
I will take some pics of the frame! ;-)
I used a different method for cleaning the brass before painting it....
I boiled some rhubarbs in water, mixed the water with some wine acid, soap and isopropyl alcohol.
I dipped the loco in that mixture for 10 minutes and used a brush to make sure all parts were cleaned.
Then I soaked it in water with some baking soda (to eliminate the acids).
I the rinsed it with warm water before dipping it in iso-alcohol (to remove all remaining water).
That procedure makes the brass super clean!
I then only handled the model with gloves before priming it!
I used Prymol from Humbrol for that.
It's a self etching primer, totally transparent and very easy to use!
I have painted the first layers of paint now, pics to follow later.
k27rgs
Posted - 07/05/2012 :  05:56:44 AM  Show Profile  Reply with Quote
Impressive [:-thumbu].
http://www.modvid.com.au/html/body_worldwide__miniatures.html
masonamerican
Posted - 07/05/2012 :  12:29:06 PM  Show Profile  Reply with Quote
Quite a concoction. Sounds like an old recipe from a medieval Alchemist book. If I may ask how have you come up with that recipe? Does it clean to non-tarnished gleaming brass?
Håkan
Page: of 3 Previous Topic Topic Next Topic
