| Author |
Topic  |
lab-dad
1484 Posts |
Posted - 03/20/2012 : 11:17:05 AM
Up next on my "to do" list is the drill press. The one I am building is based on the CHB (now Sierra West) Camelback version with auto feed. You can see the SW one here; http://www.sierrawestscalemodels.com/oscale/machine.shtml For reference here is a picture of a real one;
Mine will have the gear operated auto feed not belt driven as shown in the reference image.
The big(actually just one of them) challenge was the column. It needed to be 9/16" at the base and halfway up taper to 5/16, then a 90 degree bend. Easy..... Here is the brass rod (solid) on the lathe being tapered;
Once the taper was complete I heated it to anneal it (make it softer) and put the bend in it. Here I am attaching the upper bearing guide.
The base was milled from .250" aluminum plate. I needed the weight to keep it from tipping over, that column is heavy!
The collars for the table support are aluminum and the arm is .250" thick flat brass.
The table is three layers of styrene. This allowed me to form the "T" slots accurately. Here I am milling the through holes in the table after I turned it round on the lathe.
And here is where I am at currently.
More soon. -Marty |
Schoolmaster
1581 Posts |
Posted - 03/20/2012 : 11:21:08 AM
Recursion, making miniature machine tools with machine tools.
I look forward to developments. |
4235 Posts |
Posted - 03/20/2012 : 12:42:37 PM
Excellant work as always, Marty.
Mark |
W,L,&E |
11274 Posts |
Posted - 03/20/2012 : 1:41:03 PM
| The start of a great looking build, already with fantastic detail work. |
4899 Posts |
Posted - 03/20/2012 : 1:52:45 PM
Well Mr. Jones I see your making progress on the Drill Press. I guess I will have to go on line and find you something hard to do.
As always you don't let us down. Your machineing skills are unbelievable!!
How old would you be if you didn't know how old you are. |
8194 Posts |
lab-dad
1484 Posts |
Posted - 03/21/2012 : 07:43:03 AM
Thanks guys! Geezer, yes had planned to chuck up a 1/16 (one inch in scale)bit in it and try to drill some balsa!
-Marty |
compressor man
68 Posts |
Posted - 03/21/2012 : 8:04:04 PM
This is fantastic. I cant wait to see those step pulleys!!
My brother actually has one of these drill presses in his shop. It weighs about 900 lbs.
Chris |
Regards, Chris |
16456 Posts |
Posted - 03/22/2012 : 7:08:39 PM
| Great lathe work, Marty, and your start on the drill press whets our appetite. |
Frederic Testard |
2400 Posts |
lab-dad
1484 Posts |
Posted - 03/26/2012 : 12:26:05 PM
Working on the automatic feed gears. There are 11 gears in the picture below, the squares on the mat are one inch. The shafts are .062" for reference. Sure was fun calculating the shaft locations and fabricating the jig to align everything.
-Marty |
4899 Posts |
Posted - 03/26/2012 : 12:30:40 PM
-MJ
Not bad for a start!!! Looking forward to the next step!!!!
Jerry |
lab-dad
1484 Posts |
Posted - 03/30/2012 : 09:57:16 AM
Working my way through the gears....... The auto feed is some fiddly stuff.
I keep thinking to myself "how the hell did Charlie (Brohmmer) do this in "O" scale!!!!
I have since moved the parts a little and decided on a smaller driven gear. Turning down the cast one in this picture was sure a challenge......Oh well.
More soon. -Marty |
4899 Posts |
Posted - 03/30/2012 : 12:06:58 PM
Sure does look like Charlie's. Excellent job on the gears, Mr. Jones.
Maybe you should go into business selling these little gems.
Jerry |
lab-dad
1484 Posts |
Posted - 04/01/2012 : 2:02:05 PM
Had to get some color,finishes, pigment on the pieces. Also moving along. Some minor bits to add to the table lift (I'm getting tired of using tape to hold it up!) Also the lower quill gear can not be secured until final assembly. I am especially proud of the hand shaped handles on the table lift crank.
More soon! Thanks for looking! -Marty |
4899 Posts |
Posted - 04/01/2012 : 7:45:11 PM
Looks really excellent with some color on the gears.
They really stand out now.
Jerry |
Topic  |
